top
View previous topic
View next topic
Forum Index C-Class | C-Class (W203)    Page 1 of 1
Post new topic   Reply to topic
Mon Jul 09, 2007 9:20 pm PostPost subject: DIY: W203 Sedan Headlights
rlee02135
Addict
Posts per day: 0.74
2004 Mercedes-Benz C32 AMG
Reply with quote Add to the list of messages to quoteWithdraw from the list of messages to be quoted
As with any DIY instructions, use the instructions at your own risk.
I replaced my Bi-Xenons with the Stock healights.
You can use this process to put in Bi-Xenons, Clear Headlights or Depo Projectors into your car.
Lets Start on the Driver's Side
1) Remove the 8mm screw in theis hole
2) Remove the 8mm bolt here
3) Jack up the car and remove the wheel
4) Remove the bottom bumper cover by taking out a few push pins and some 8mm screws
5) Remove a few push-pins and 10mm nuts, then push aside the inner fender
6) Remove the T20 Torx screw under where the bumper meets the fender
7) Pull out the bumper-fender clip. You may need a screwdriver to pry it out
8) Remove the 8mm bolt on top of the headlight
9) Remove the 8mm bolt on the left side of the headlight
10) Pull the bumper down a little, and remove the 8mm bolt on the right side of the headlight
11) Unplug the connector from the headlight
12) Take off the two T20 Torx screws and put the black piece on the new headlight
13) Place the headlight back in the hole carefully, and plug in the connector
14) Put the 8mm bolt back on top of the headlight
15) Put the 8mm bolt back on the left of the headlight
16) Put the 8mm and the plastic piece that goes with it back on the right side of the headlight
17) Make sure the fender clips on to the bumper
18) Put the bumper-fender clip back in, pushing towards the front of the car
19) Put the T20 Torx screw back into bumper-fender clip
20) Put the 8mm bolt back in here
21) Put the 8mm screw back in the hole
22) Put the wheel back on
Result:
Now the Passenger Side
1) Remove the 8mm screw in this hole
2) Remove this 8mm bolt
7) Pull out the bumper-fender clip. You may need a screwdriver to pry it out.
9) Remove the 8mm bolt on the right side of the headlight
10) Pull the bumper down a little, and remove the 8mm bolt on the left side of the headlight
15) Put the 8mm bolt back on the right side of the headlight
Final Result:
_________________
Back to top
View user's profile Send private message
Mon Jul 09, 2007 9:29 pm PostPost subject:
MikeSSw203
Mikey C, MiKey Want
Posts per day: 7.28
2005 Mercedes-Benz C Class
beat me to it!
Great work Robert
_________________
Back to top
View user's profile Send private message   Visit poster's website AIM Screen Name
Mon Jul 09, 2007 11:14 pm PostPost subject:
SDSilverM3
     Ling
Posts per day: 9.37
2005 Mercedes-Benz C55 AMG
Now that's what you call a write-up.
_________________
'05 Mercedes-Benz C55 AMG
Car: Alabaster White | Black Leather w/Birdseye Maple Trim | Lighting Package | NAV | Steel Carter Plate (Option 481)
Mods: KW V2 Coilovers | 19x8.5F/19x9.5R BBS LM | Toyo T1R Tires (235/35/19F 265/30/19R) | Euroteck Carbon Fiber Front Lip | Painted Sidemarkers | OEM Flat Hood Emblem | Fuel Content Mod | Netherlands Setting Mod
www.Ling-Ly.com
Back to top
Mon Jul 09, 2007 11:29 pm PostPost subject:
Benzoboi
Post Connoisseur
Posts per day: 11.24
2003 Mercedes-Benz E55 AMG
Awesome!~!
_________________
4 door sedan with a couple "go fast" mods and some wheels...
Another great sig brought to you by Shake!
Back to top
Wed Aug 15, 2007 4:32 pm PostPost subject:
bgnire
n00b
Posts per day: 0.01
Nice One, Robert !
I follow your instruction and Install my Bi-Xenon with big success .
Back to top
Wed Aug 15, 2007 4:37 pm PostPost subject:
ijnoj09
Addict
Posts per day: 0.73
2008 Mercedes-Benz C300
nice write-up the bumper clip is a bitch to put back in
_________________
Back to top
Wed Aug 15, 2007 4:40 pm PostPost subject:
hi its me arya
Blowup Doll Pimp
Posts per day: 3.36
Nice write up!
why you switch to the C230 Bumper and put your stock lights back in?
_________________
Under Construction
Back to top
Wed Aug 15, 2007 4:41 pm PostPost subject:
Mark Cummins
Moderator
Posts per day: 0.99
Nice Write up!
One Note is to Version Code the Car to XENON PRESENT Via the SDS aka STAR to avoid the lights from flickering
Back to top
View user's profile Send private message [ Hidden ]
Wed Aug 15, 2007 4:46 pm PostPost subject:
rlee02135
Addict
Posts per day: 0.74
hi its me arya wrote:
Nice write up!
I had a C230, which I parted out to buy the C32
_________________
Back to top
Wed Aug 15, 2007 5:18 pm PostPost subject:
hi its me arya
Blowup Doll Pimp
Posts per day: 3.36
going for the sleeper look?
_________________
Under Construction
Back to top
Wed Aug 15, 2007 5:30 pm PostPost subject:
rlee02135
Addict
Posts per day: 0.74
no, seriously. i had a C230 in April of 2004, then parted out and bought a C32 in Feb 2007.
C230:
C32:
_________________
Back to top
Wed Aug 15, 2007 5:32 pm PostPost subject:
rlee02135
Addict
Posts per day: 0.74
you could even see the engine in the DIY pics...
_________________
Back to top
Wed Aug 15, 2007 5:34 pm PostPost subject:
hi its me arya
Blowup Doll Pimp
Posts per day: 3.36
OHHH NVM... I though you were doing this to your C32
_________________
Under Construction
Back to top
Tue May 27, 2008 5:02 pm PostPost subject:
C230 Sport Coup
n00b
Posts per day: 0.06
Thanks guys.
I'll be doing this tomorrow.
I made a pdf out of it, the pics are slightly smaller, and only did the one side,
since it's essentially the same process.
W203 Remove headlights.pdf
 Description:
Download
 Filename:  W203 Remove headlights.pdf
 Filesize:  2.07 MB
 Downloaded:  278 Time(s)
_________________
"It's not just about me an my dream of doing nothing, it's about all of us!" - Office Space
Bi-Xenon's, 2005 tails & Mirror Blinkers from Blake
Tinted Windows-Tinted Tails- Clear Sides- Clear Fogs-
ASP Pulley-NGK Iridium BCPR7EIX-11 (5691) 2 steps Cooler Plugs
Supersprint Header-Remus Muffler- AR20 Rasp eliminator
TEIN SS Coilovers
AMG; Wheels, Front Swaybar 22mm, C32 Brakes, License Frame
H&R Rear 19mm swaybar (this combo is the shiz for a coupe!!)
Akebono Ceramic Brake Pads (Front)
Bridgstone A050 Pole Position Tires (awesome! But the rear went at 10K mile, replaced with Sumi HTR3's also awesome for 1/2 the price)
Audio 10
Rear Spoiler (Rentech replica)
Back to top
Post new topic  Reply to topic    Page 1 of 1
Advertisers/Affiliates Index | Advertising Inquiries
Post new topic   Reply to topic Forum Index -> C-Class | C-Class (W203)
View previous topic
View next topic
Display posts from previous:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Jump to:
