top
View previous topic
View next topic
Performance Upgrades and Engine Theory Forum Exclusively Sponsored by:
TAG Motorsports
2181 Meyers Avenue
Escondido, CA 92029
Toll Free: (800) 928-1766
Forum Index | Performance Upgrades and Engine Theory Goto page Previous  1, 2   Page 2 of 2
Post new topic   Reply to topic
Wed Jul 15, 2009 9:27 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
1997 Mercedes-Benz E320
Reply with quote Add to the list of messages to quoteWithdraw from the list of messages to be quoted
How about a 100 so I can drive up there and turn it into a monster?
Goliath27 wrote:
You still coming up to Cleveland?
ALi
I'll be coming up either this weekend or the weekend after Import Alliance. I have a junked holset turbo the same size as T70 that I can bring just so you can get an idea of the size of such a system.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
MSN - maxwellhughes@msn.com
Want to turbo your M112, M113, M119, M272 or M273?
All the info you need is right here:
http://mymbonline.com/forum/viewtopic.php?t=19996&highlight=
Want to turbo your M104? PM me.
Back to top
View user's profile Send private message [ Hidden ]
Wed Jul 15, 2009 10:12 pm PostPost subject:
Milkm4n
p0st wh0r3
Posts per day: 11.79
i might be a bit behind on the subject but your saying you can turbo my 2.5 v6?....
if the answer to my question is yes then ..... how much and when
if the answer is no than sorry for wasting you time making you read this comment
_________________
[/quote]
Back to top
Wed Jul 15, 2009 10:42 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Haha I'd never turn down a turbo request. I need to build a turbo push lawnmower just to prove how much I love turbo's .
Take the Turbo CLK430 list on the bottom of the first page and modify a couple things:
Use these injectors: http://cgi.ebay.com/Ford-Racing-30-lb-pound-fue...93%3A1%7C294%3A50
and a 45 trim .42./.48 turbo. You could run a cheap ebay 45 trim until you got the money for a real garrett if you want to finish the kit quick.
AEM F/IC-6:
http://cgi.ebay.com/ebaymotors/AEM-FUEL-IGNITIO...9%3A1%7C72%3A1171
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Jul 16, 2009 4:30 pm PostPost subject:
Williams707
First Base
Posts per day: 0.37
What performance gains would a V6 CLK 320 (W208) have?
I'm overseas so I am trying to figure out who could tune the ECU or is it enough just to run the PowerChip ECU flash?
_________________
Back to top
View user's profile Send private message   Visit poster's website
Fri Jul 17, 2009 1:11 am PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
The powerchip wouldnt work, use the AEM FIC6 I listed in my previous post. As for performance gains, you probably get 70-100 more horsepower with a 6-7 psi spring. Probably more since it's a dual plug 3 valve motor.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Jul 30, 2009 2:58 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
In answer to some recent PM's here is an M112 auxilary bolt. It is the same bolt used in the m113, m272, and m273. It is located facing foward on the front of the engine just below and to the left of the oil filter canister.
The auxilary bolt is replaced by the 12x1.5mm to -3AN conversion piece to feed pressurized oil to the turbo. Its after the oil filter too so it's clean.
The auxilary plugs on the M112, M113, M119, M272, and M273 all use the same 12x1.5mm plug as pictured and verified thanks to Lowes :
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sat Aug 01, 2009 11:48 am PostPost subject:
Mu9enx
Addict
Posts per day: 0.58
2001 Mercedes-Benz C320
Will my car smoke 335i's with a rear turbo?
Realistically, what would an extra 70-100hp net for a 3800lb m112 sedan that only has 218hp/221tq stock?
I really wouldn't mind doing something as adventurous as this, since my car is going to be outta warranty soon, but I want to know if it's going to be a good investment?
_________________
Back to top
View user's profile Send private message   AIM Screen Name
Sat Aug 01, 2009 3:58 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
I don't know where I got 70-100 horsepower from. I was probably typing while I was tired. Your 320's will respond like my 320 except you will make significantly more torque than mine and the engines will respond better to the boost with the dual plugs and three valves. Plugging in all the parameters for the 3.2L m112 with a 6psi spring on a 70F degree day your car will be making around 320whp(ironic) or 375bhp. A little more than a 335i lol.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sat Aug 01, 2009 9:11 pm PostPost subject:
Mu9enx
Addict
Posts per day: 0.58
That's what I like to hear!
Really thinking about it in the long run, is it possible to run a larger turbine to make even more power? Or will it compromise the engine if I wanted to up the boost to 1 bar? How many psi will our motors be able to handle as a DD?
_________________
Back to top
Sun Aug 02, 2009 12:39 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
On the stock engine I wouldn't want to go over 9 psi unless the car has low mileage or the pistons are replaced. 1 bar is too much for the high compression, I would get 9:1 pistons from ROSS for 600-700 if you want to boost 1bar-1.8bar with a Masterpower T70 turbo.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sun Aug 02, 2009 4:27 pm PostPost subject:
Mu9enx
Addict
Posts per day: 0.58
Just to be on the safe side, with the boost upped to 8-9, what then would the power figures look like?
_________________
Back to top
Mon Aug 03, 2009 2:06 am PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Using the same parameters I'm getting 345whp and 362whp or 405bhp and 425bhp respectively.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sat Aug 15, 2009 9:18 pm PostPost subject: STS for M119?
need2speed
n00b
Posts per day: 0.02
I was pointed to this thread from another forum because I was interested in the STS system for my M119 motor. Great discussion and lots of knowledge here!
Max, do you have a similar parts list for a single turbo M119 install? I'm interested in your recommended components that would improve on the STS kit parts.
BTW, the install on your motor looks very very tidy
Back to top
Sun Aug 16, 2009 10:29 am PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Thanks. Use a Turbowerx EXA-Pump oil scavenge pump and a 3an full flow oil feed instead of the 4an feed and shitty oil pump STS supplies. Also have your valve cover tapped and welded instead of drilling a hole in the oil cap for oil return.
Is your M119 Jetronic or Electronic Fuel Injected?
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sun Aug 16, 2009 12:29 pm PostPost subject:
ZorroAMG
W124 pimp
Posts per day: 2.84
1990 Mercedes-Benz E Class
If need2Speed doesnt answer first, I believe the 500E M119 is electromechanical fuel injection. He may be using a standalone like SDS or megasquirt...I could be wrong though but that's what you need for the M103 to turbo it properly.
_________________
Back to top
Sun Aug 16, 2009 1:04 pm PostPost subject:
ddmracing05
Broken in!
Posts per day: 4.39
1997 Mercedes-Benz 230
Im still waiting!!!
_________________
Spending money I don't have, to buy parts I really don't need, to impress people I don't know!
Back to top
View user's profile Send private message   AIM Screen Name Yahoo Messenger
Sun Aug 16, 2009 5:30 pm PostPost subject:
need2speed
n00b
Posts per day: 0.02
Thanks for the info Max. Mine is a Bosch LH Jetronic (Seimens also made them).
Hi Zorro...howzitgoin?
_________________
"Lead, follow, or better yet, get out of the way."
E500 owner's motto
Back to top
Sun Aug 16, 2009 5:51 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
ddmracing05 wrote:
Im still waiting!!!
Lol haven't had much time to work on the 4 cyl manifold but when it's done I'll let you know so you can test fit it.
need2speed:
You will need a split second additional injector computer in order to tune your car. www.splitsec.com -> Products -> Additional Injector Controllers -> AIC1. You will probably need two 670-1000cc EV1 body injectors.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Sat Aug 22, 2009 4:39 pm PostPost subject:
need2speed
n00b
Posts per day: 0.02
OK, thanks Max. I found a local STS dealer and we'll chat...
_________________
E500 owner's motto
Back to top
Wed Aug 26, 2009 11:20 pm PostPost subject:
GLK4matic
Forever 2nd place
Posts per day: 154.09
2010 Mercedes-Benz GLK350 4matic
Anyone happen to know of an MB dealer in NorCal that would service our rides and not Chuttoyy us.....errrh...I mean Code8 us if we have a turbo? I know it sounds like alot to ask, but it is worth a shot.
_________________
2010 GLK Whorematic
MB Arts Strut brace | MB Arts rear brace | MB Arts badging | Res delete | Sec cat delete | modded airbox | K&N's | Powdercoated wheels | Tinted taillights | Black grille | MB Arts 2" lowering springs | Blackedout mufflers
Back to top
Thu Sep 10, 2009 6:05 am PostPost subject:
TemjinX2
n00b
Posts per day: 0.07
The is answer is no..its not a good investment. It'll be cheaper for you to trade in your c320 for a c32. You will auto fail smog with the turbo kit unless you want to take off and put back on your turbo kit every 2yrs.
_________________
2002 C32 AMG
Back to top
Thu Sep 10, 2009 9:26 am PostPost subject:
GLK4matic
Forever 2nd place
As long as he leaves all emissions equipment on his ride he will be fine when it comes time to smog his ride. Cars that have turbos burn cleaner than cars without.
_________________
2010 GLK Whorematic
Back to top
Thu Sep 10, 2009 12:16 pm PostPost subject:
drb930
n00b
Posts per day: 0
Subscribed!
Back to top
Sun Sep 20, 2009 9:09 pm PostPost subject:
xsuperbeex
silverbee
Posts per day: 13.59
subscribed...
_________________
Current Mods: MRR HR5, MOMO Pedals, MOMO Floor Mats, MOMO Shift Knob, Pioneer AVH-P5100DVD, Neon Footwell, Replica Brabus Front Lip, Rear Spoiler Lip, Clear Bumper Light, 8000 HID Bi-Xenon Headlight and Fog light, Blue Interior LED, 35% Tint, AMG Rear Bumper, Custom Quad Exhaust, Mattig Grille, H&R spring
Coming Up: Euro impact strips
Back to top
View user's profile Send private message   MSN Messenger
Thu Oct 15, 2009 8:00 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Y'all have probably seen it twice over but just in case... Hersh's CLK430 Turbo. Interesting tid bit: At 90 some thousand miles his pre cats basically collapsed prior to the install of the turbo and his cats were getting burned. I will now make it a note that if you go into a rear mount turbo, do a couple WOT passes prior to turboing the car and if it doesn't smell like rotten eggs(the age old sign of melting catalytic material) or throw a code then your good. Upgrading to metal substrate primary cats and deleting the pre-cats wouldn't be a bad idea either.
Now the video:
Raw footy:
Link
Quick edit build video:
Link
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Wed Dec 09, 2009 4:54 pm PostPost subject:
jk062602kj
n00b
Posts per day: 0.01
Max Hughes you are a genius. I'm from MBWorld and I heard you are a turbo monster. Can you be soo kind enough and give me some detail to set up a turbo on a w203 m272 3.5?
I have no clue about turbos but like you I am not a huge supercharger fan. To be honest with you turbos run in the family but i'm complete clueless.
http://www.youtube.com/watch?v=gWp9pOSR290
http://www.youtube.com/watch?v=7MVDIuUo1oY
http://www.youtube.com/watch?v=FAdWbnGK3kE
Thank You Very Much,
Karo
P.S. I know my car will never be able to get to this status but even a little would help.
Thanks again
Back to top
Wed Dec 09, 2009 9:23 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Yea no problem. Gimme a little bit to compile a list for that.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Dec 10, 2009 12:51 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
C350, engine bay setup.
Parts Cost
Garrett T4/60-1 Turbocharger $830
Custom turbo up pipe $500
3AN oil feed $13.00
10AN Oil Drain $18
3AN oil feed line - 28" $21
10AN oil Drain - 24" $15
10AN straight fitting $7
10AN 45 fitting $13
10AN to 1/2 NPT fitting $9.75
12x1.5mm fitting $25
2.5" I/C piping kit $93
3.25 to 2.5 coupler $26
TiAl 38mm Wastegate and BOV $434
Garrett 400hp Intercooler $470
Bosch 440cc injectors x6 $38
Down pipe flange kit $34
AEM F/IC-6 $362
Wideband O2 Gauge and Sensor $178
Complete Total $3,086
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Dec 10, 2009 2:39 pm PostPost subject:
jk062602kj
n00b
Posts per day: 0.01
Thanks Max,
once I get this done you know i'll be representing your shop or you (put a Max Hughes sticker on my car) smile
Can I mount the turbo before the exhaust? What about tuning? I will need an ECU tune? How would I handle the fuel/air?
Thanks,
Karo
Back to top
Thu Dec 10, 2009 7:04 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Yea there is just enough room in the w203 to put the turbo in the engine bay but a rear mount setup could be done more easily. It all depends on what you want. The AEM F/IC-6 will take care of the tuning and it is the anwer for all 3 of those remaining questions lol. It is the tuner, it tunes the ECU and it controls the fuel/air mixture.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Dec 10, 2009 10:38 pm PostPost subject:
brabus247
Addict
Posts per day: 0.8
what happened to hersh's car?? he went a bit quiet
_________________
Back to top
Thu Dec 10, 2009 11:25 pm PostPost subject:
jk062602kj
n00b
Posts per day: 0.01
All I got to say is you're a God
Thanks for all the info. I really really really appreciate you taking the time to make a list and answering my noob questions
Back to top
Sun Dec 13, 2009 8:03 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
We fixed every thing in the intake and exhaust tract that could have been the problem and I am quite certain it is just the turbo itself. We didn't have anytime to work on the car but now we are in a position where I can repair the turbo and we can get the car boosting.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Tue Feb 23, 2010 9:18 pm PostPost subject:
SLAMMED_C
Addict
Posts per day: 1.06
Would this be the same size as on an M111 block as well?
_________________
*1999 C230Kompressor- aka C23k* soon C23T!!
--N/A Converted Belt Drive--SLOW AS FUCK!!--18" SL55 AMG's--KW V2 Suspension--Blacked Out Grill--Black Projector Headlights--C36 Rear--
COMING SOON: Brabus Front--Custom Turbo Project Begins--6 speed manual trans--LED/Smoked Tails--New Projector Headlights--
*2002 E320 4Matic*
--Cut Springs--Bluetooth--Voice Control--Euro Comand--Roof GPS Antenna--MB TV Tuner--DVD Player--///AMG E55 Front and Rear Bumpers with Fogs--Black Housing Halo Projector Headlights--Staggered 19" Mandrus Emil's--LED daytime running lights--Custom Exhaust--
COMING SOON: --8000K Low Beam and Fogs--LED/Smoked Tails--Lip Spoiler--
Back to top
Wed Feb 24, 2010 12:33 am PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Yep. All the Mercedes motors since the m103 on have 12x1.5mm plugs in the filter housing.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Mon Mar 08, 2010 3:08 pm PostPost subject:
dokotela
n00b
Posts per day: 0.49
hi there max.
very interesting indeed.
what are my options considering i have a m111 kompressor engine?
how easy would it be to twincharge with a remote turbo setup?
any/all info would be greatly appreciated.
Back to top
Mon Mar 08, 2010 8:10 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
You don't need to do a remote setup with a M111 kompressor powered car. While the supercharger obstructs access to the oil pan you can use a small scavenge pump and send it back through the valve cover or pump it around the S/C into the oil pan.
I have been putting a lot of thought into twin charging and I think that if done correctly you can maintain all the stock functions of the car including the secondary air intake without bleeding the boost out. That simplifies the parts needed and allows for a simple AEM F/IC tuning computer to be installed instead of going with the more expensive ECU flashing route.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Mon Mar 08, 2010 10:34 pm PostPost subject:
dokotela
n00b
Posts per day: 0.49
you got me confused.
how about a little rough sketch to show how this will be done.
Back to top
Tue Mar 09, 2010 5:19 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Never mind about the secondary intake I suggested, it will have to be removed but it can be nullified.
Just picture it looking a lot like this picture but the supercharger will still be attached(in the stock location it is right below the turbo). Your intake will also remain stock unlike this dudes. This is "Pagz" from peachparts.com
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Wed Mar 24, 2010 10:56 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Hmm what did these baby's come off of?
Cant wait for these suckers to come in so I can rebuild them into something much more interesting
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Thu Mar 25, 2010 4:29 pm PostPost subject:
Williams707
First Base
Posts per day: 0.37
CLK W208 or E W210
_________________
Back to top
Thu Mar 25, 2010 4:55 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
W220 But they are going on a W208 once completed smile. Hoping for cross compatibility between most of the M113 equipped models with this design.
After that the m112 is finally getting some boost.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Fri Mar 26, 2010 5:49 pm PostPost subject:
Williams707
First Base
Posts per day: 0.37
I was so close but they do look similar Since you mentioned a W208, I'm guessing you are taking a trip to New Jersey or he's doing another road trip to IN or a new W208 project?
_________________
Back to top
Mon Apr 12, 2010 2:06 pm PostPost subject: help plz
edrisennab
n00b
Posts per day: 0.02
2005 Mercedes-Benz 320
i own a 2005 clk320 with an automatic transmision i was wondering if i could turbocharge it????
Back to top
Mon Apr 12, 2010 7:02 pm PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
Yes it can be turbocharged.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Mon Apr 12, 2010 8:47 pm PostPost subject:
DuaneC55
n00b
Posts per day: 0.22
Not to question the post, but "no turbo lag" is a bit hard to beleive with this rear mount system. Look at the distance between boost side running from the rear of the car to the engine. Turbo's also thrive on exhaust manifold temperature, most of the thermal value is lost by the time the exhaust reaches the back of the car. The only way this system can acheive "no turbo lag" is to use a small turbo that comes on boost just off idle. But this will kill your top end. The only manufacturer that puts turbos in the rear of the car is Porsche, but the engine is there also. You can try to fool the physics of volumetric and thermal efficiency, but it’s unlikely you'll succeed.
_________________
Current
2003 996TTX50
2009 C63
2006 X3
In Loving memory of my bank account
2005 C55
1999 C43
1997 M3 4Dr
1995 325 4Dr
1985 318i
1995 Porsche 993 RS
1985 Porsche 911 widebody
1983 Porsche 911 Cab
1980 Porsche 911
1978 Porsche 911
Back to top
Wed Apr 14, 2010 1:12 am PostPost subject:
Max Hughes
Max Booost!
Posts per day: 0.56
By no turbo lag I mean if you brake launch from a stop you will be boosting immediately once you take off or if you punch it from a roll.
The easy way to counter act turbo lag is to use a smaller turbine housing while keeping the same compressor housing. It's not rocket science. It's what every remote mount turbo setup will do. You have the same size turbo you would have used in the engine bay with a smaller exhaust side.
Heat creates a higher volume of gas, it does not change the velocity of the gas. The turbine housing is what manages the velocity of the gas. In a traditional setup you use the bigger turbine housing instead of a small one because at higher RPM it will build up excessive back pressure and reduce efficiency. The remote setup can use the smaller turbine to maintain quick response but because their is less heat(hence less volume) it will maintain the same or better levels of efficiency at WOT on the exhaust side.
_________________
AIM - Pro60modman
Yahoo - Pro60modman
Back to top
Mon Jun 21, 2010 8:16 pm PostPost subject: Re: So you want to turbo your modern Mercedes? V6 and V8.
jimmyskullz
n00b
Posts per day: 0.03
I'm on board for this,...
Back to top
Post new topic  Reply to topic Goto page Previous  1, 2   Page 2 of 2
Advertisers/Affiliates Index | Advertising Inquiries
Post new topic   Reply to topic Forum Index | Performance Upgrades and Engine Theory
View previous topic
View next topic
Display posts from previous:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Jump to:
